Salta al contenuto principale
HP 2000 - 2D22DX Wireless Card Replacement
Cosa ti serve
  1. HP 2000 - 2D22DX Wireless Card Replacement, Battery: passo 1, immagine 1 di 2 HP 2000 - 2D22DX Wireless Card Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX Wireless Card Replacement: passo 2, immagine 1 di 2 HP 2000 - 2D22DX Wireless Card Replacement: passo 2, immagine 2 di 2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX Wireless Card Replacement, Wireless Card: passo 3, immagine 1 di 2 HP 2000 - 2D22DX Wireless Card Replacement, Wireless Card: passo 3, immagine 2 di 2
    • Locate the RAM compartment cover below the battery compartment.
    • Locate the Phillips head screw securing RAM compartment to plastic chassis.
    • Loosen screw that is securing the RAM compartment with #00 Phillips head screwdriver.
    • Screw is permanently attached to the RAM compartment cover. Do not try to remove completely.
  4. HP 2000 - 2D22DX Wireless Card Replacement: passo 4, immagine 1 di 2 HP 2000 - 2D22DX Wireless Card Replacement: passo 4, immagine 2 di 2
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
  5. HP 2000 - 2D22DX Wireless Card Replacement: passo 5, immagine 1 di 1
    • Locate the wireless module next to the RAM slots.
  6. HP 2000 - 2D22DX Wireless Card Replacement: passo 6, immagine 1 di 3 HP 2000 - 2D22DX Wireless Card Replacement: passo 6, immagine 2 di 3 HP 2000 - 2D22DX Wireless Card Replacement: passo 6, immagine 3 di 3
    • Locate the gold connecting wire attached to the wireless module. It is labeled with a small sticker that has a circled number one.
    • Using a plastic spudger, disconnect the gold-end of the connecting wire from the wireless module.
    • Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the gold wire and its respective port on the wireless module. Both are very fragile and can be easily ruined.
  7. HP 2000 - 2D22DX Wireless Card Replacement: passo 7, immagine 1 di 3 HP 2000 - 2D22DX Wireless Card Replacement: passo 7, immagine 2 di 3 HP 2000 - 2D22DX Wireless Card Replacement: passo 7, immagine 3 di 3
    • Locate the small Phillips head screw in the top right corner of the wireless module.
    • Using a #00 Phillips head screwdriver, remove the screw and set aside.
    • The wireless module should now pop up from its slot at a 45 degree angle.
  8. HP 2000 - 2D22DX Wireless Card Replacement: passo 8, immagine 1 di 1
    • Slowly slide the wireless module straight out from its slot in the logic board.
    • Maintain the 45 degree angle of the wireless module until all pins are disconnected. Failure to do so may result in breaking the wireless module connecting pins.
Conclusione
Altre 5 persone hanno completato questa guida.
Conor Most
Membro da: 04/14/14
2.687 Reputazione
6 Guide realizzate
Cal Poly, Team 3-40, Maness Spring 2014 Membro di Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,986
