Salta al contenuto principale
HP 2000 - 2D22DX Hard Drive Replacement
Cosa ti serve
  1. HP 2000 - 2D22DX Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP 2000 - 2D22DX Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX Hard Drive Replacement: passo 2, immagine 1 di 2 HP 2000 - 2D22DX Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Loosen the Phillips #00 screw securing the RAM compartment cover.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
  4. HP 2000 - 2D22DX Hard Drive Replacement: passo 4, immagine 1 di 2 HP 2000 - 2D22DX Hard Drive Replacement: passo 4, immagine 2 di 2
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
  5. HP 2000 - 2D22DX Hard Drive Replacement: passo 5, immagine 1 di 3 HP 2000 - 2D22DX Hard Drive Replacement: passo 5, immagine 2 di 3 HP 2000 - 2D22DX Hard Drive Replacement: passo 5, immagine 3 di 3
    • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
    • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
    • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
  6. HP 2000 - 2D22DX Hard Drive Replacement: passo 6, immagine 1 di 3 HP 2000 - 2D22DX Hard Drive Replacement: passo 6, immagine 2 di 3 HP 2000 - 2D22DX Hard Drive Replacement: passo 6, immagine 3 di 3
    • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
  7. HP 2000 - 2D22DX Hard Drive Replacement: passo 7, immagine 1 di 3 HP 2000 - 2D22DX Hard Drive Replacement: passo 7, immagine 2 di 3 HP 2000 - 2D22DX Hard Drive Replacement: passo 7, immagine 3 di 3
    • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
    • Lift the hard drive out and away from its socket in the plastic chassis.
Conclusione
Altre 27 persone hanno completato questa guida.
Conor Most
Membro da: 04/14/14
2.687 Reputazione
6 Guide realizzate
Cal Poly, Team 3-40, Maness Spring 2014 Membro di Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 40
Tutti i Tempi: 14,556
