Salta al contenuto principale
HP 17-x061nr Hard Drive Replacement
Cosa ti serve
  1. HP 17-x061nr Hard Drive Replacement, HP 17-x061nr  Disassembly: passo 1, immagine 1 di 3 HP 17-x061nr Hard Drive Replacement, HP 17-x061nr  Disassembly: passo 1, immagine 2 di 3 HP 17-x061nr Hard Drive Replacement, HP 17-x061nr  Disassembly: passo 1, immagine 3 di 3
    • With the laptop upside down, remove the battery by hand and the twelve 7.0 mm screws that are holding the back case to the front. Use a JIS #0 screwdriver to remove the screws.
  2. HP 17-x061nr Hard Drive Replacement: passo 2, immagine 1 di 2 HP 17-x061nr Hard Drive Replacement: passo 2, immagine 2 di 2
    • Peel back the rubber footrests located next to the battery, on the left and right sides.
    • Remove the two 7.0 mm screws underneath the rubber feet using a JIS #0 screwdriver.
  3. HP 17-x061nr Hard Drive Replacement: passo 3, immagine 1 di 1
    • Slide the optical drive out and away from the laptop.
  4. HP 17-x061nr Hard Drive Replacement: passo 4, immagine 1 di 3 HP 17-x061nr Hard Drive Replacement: passo 4, immagine 2 di 3 HP 17-x061nr Hard Drive Replacement: passo 4, immagine 3 di 3
    • Flip the computer over and use a plastic opening tool to wedge between the back and front cases.
    • Trace the perimeter of the laptop. Make sure to keep the tool inserted between the front and back cases. You will hear popping sounds as the back case becomes disengaged from the front plate.
    • Flip the laptop over and lift the back case off. Now you have access to all of the internal hardware.
  5. HP 17-x061nr Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Locate the hard drive.
    • Using the purple hard plastic tab gently pull the cable tape tab out of the input, located on the left-hand side.
  6. HP 17-x061nr Hard Drive Replacement: passo 6, immagine 1 di 2 HP 17-x061nr Hard Drive Replacement: passo 6, immagine 2 di 2
    • Carefully peel back the cable tape from the hard drive itself.
    • Pull the shock absorbers from the back of the hard drive casing.
  7. HP 17-x061nr Hard Drive Replacement: passo 7, immagine 1 di 1
    • Lift up the back of the hard drive module and gently pull it away from the connection point.
    • Be sure to keep the replacement within the package until you are ready to place it.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Will this work for HP Notebook - 17-y018ca
hamiltoncomputes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,799
