Salta al contenuto principale
HP 17-x061nr Battery Replacement
  1. HP 17-x061nr Battery Replacement, Battery: passo 1, immagine 1 di 2 HP 17-x061nr Battery Replacement, Battery: passo 1, immagine 2 di 2
    • With the power off, turn the laptop over.
    • The battery is located at the back of the laptop next to the screen hinges.
    • Move the locking tab on the right-hand side into the unlocked position by pushing it to the left. This tab will stay in the unlocked position.
  2. HP 17-x061nr Battery Replacement: passo 2, immagine 1 di 1
    • Locate the spring loaded tab on the left-hand side and push to the right to unlock it.
    • Holding the tab in the unlocked position pull the battery out, away from the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,031
