Introduzione
The motherboard is the link between all the different components in the computer. If you've had your device for a while and it malfunctions, you might assume it's a problem with the motherboard. Before you start opening up the device, check connection and peripherals and listen for beeps.
Cosa ti serve
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
Lift the USB port over and away from hard drive.
