Salta al contenuto principale
HP 17-bs049dx Fan Replacement
Cosa ti serve
  1. HP 17-bs049dx Fan Replacement, Battery: passo 1, immagine 1 di 1
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx Fan Replacement, Back Panel: passo 2, immagine 1 di 1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx Fan Replacement: passo 3, immagine 1 di 1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx Fan Replacement: passo 4, immagine 1 di 2 HP 17-bs049dx Fan Replacement: passo 4, immagine 2 di 2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx Fan Replacement: passo 5, immagine 1 di 1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. HP 17-bs049dx Fan Replacement, Fan: passo 6, immagine 1 di 3 HP 17-bs049dx Fan Replacement, Fan: passo 6, immagine 2 di 3 HP 17-bs049dx Fan Replacement, Fan: passo 6, immagine 3 di 3
    • Unscrew all four screws connecting the heatsink to the motherboard.
    • The screws holding the heat sink will not detach from the heat sink.
    • All four screws must be loosened before removing the heat sink.
    • After loosening all screws remove the heat sink and store it in a safe place.
  7. HP 17-bs049dx Fan Replacement: passo 7, immagine 1 di 1
    • After removing the heat sink, disconnect the cable connecting the fan to the motherboard.
  8. HP 17-bs049dx Fan Replacement: passo 8, immagine 1 di 1
    • Remove the old fan from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 721
