Salta al contenuto principale
HP 15-r137wm TouchSmart Screen Replacement
Cosa ti serve
  1. HP 15-r137wm TouchSmart Screen Replacement, Front Panel Assembly: passo 1, immagine 1 di 3 HP 15-r137wm TouchSmart Screen Replacement, Front Panel Assembly: passo 1, immagine 2 di 3 HP 15-r137wm TouchSmart Screen Replacement, Front Panel Assembly: passo 1, immagine 3 di 3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Screen Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Screen Replacement: passo 3, immagine 1 di 1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Screen Replacement: passo 4, immagine 1 di 2 HP 15-r137wm TouchSmart Screen Replacement: passo 4, immagine 2 di 2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Screen Replacement, Keyboard: passo 5, immagine 1 di 2 HP 15-r137wm TouchSmart Screen Replacement, Keyboard: passo 5, immagine 2 di 2
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Screen Replacement: passo 6, immagine 1 di 2 HP 15-r137wm TouchSmart Screen Replacement: passo 6, immagine 2 di 2
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
  7. HP 15-r137wm TouchSmart Screen Replacement, CD Drive: passo 7, immagine 1 di 2 HP 15-r137wm TouchSmart Screen Replacement, CD Drive: passo 7, immagine 2 di 2
    • Slide the CD drive out slowly by pulling it to the right. There are no screws attached, but there is a connection to the motherboard.
  8. HP 15-r137wm TouchSmart Screen Replacement, Cooling Fan: passo 8, immagine 1 di 2 HP 15-r137wm TouchSmart Screen Replacement, Cooling Fan: passo 8, immagine 2 di 2
    • Locate the small connection on the motherboard and disconnect it by slowly pulling it away from the motherboard.
    • Slowly disconnect the cable as the wires are very small and fragile
  9. HP 15-r137wm TouchSmart Screen Replacement: passo 9, immagine 1 di 2 HP 15-r137wm TouchSmart Screen Replacement: passo 9, immagine 2 di 2
    • Remove the three (3) 2.5mm by 3.5mm Phillips #0 screws from the fan.
  10. HP 15-r137wm TouchSmart Screen Replacement: passo 10, immagine 1 di 1
    • Remove the cooling fan from the housing carefully.
    • The fan may be connected to the small foam screen. Pull gently to release it.
  11. HP 15-r137wm TouchSmart Screen Replacement, Screen: passo 11, immagine 1 di 2 HP 15-r137wm TouchSmart Screen Replacement, Screen: passo 11, immagine 2 di 2
    • Remove the 5.5mm Phillips #0 screw.
  12. HP 15-r137wm TouchSmart Screen Replacement: passo 12, immagine 1 di 2 HP 15-r137wm TouchSmart Screen Replacement: passo 12, immagine 2 di 2
    • Gently pull and slide the video card out of its connector.
  13. HP 15-r137wm TouchSmart Screen Replacement: passo 13, immagine 1 di 2 HP 15-r137wm TouchSmart Screen Replacement: passo 13, immagine 2 di 2
    • Lift up tape, and then remove the power cable from its connector.
  14. HP 15-r137wm TouchSmart Screen Replacement: passo 14, immagine 1 di 3 HP 15-r137wm TouchSmart Screen Replacement: passo 14, immagine 2 di 3 HP 15-r137wm TouchSmart Screen Replacement: passo 14, immagine 3 di 3
    • Remove all four (4) 5.5mm Phillips #0 screws.
    • Remove the one (1) 2.5mm Phillips #0 screw.
    • Since all of the screws are now removed, the screen will begin to fall off on its own. make sure the screen is supported before removal.
  15. HP 15-r137wm TouchSmart Screen Replacement: passo 15, immagine 1 di 1
    • The screen can now be lifted out of place from the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 658
