Introduzione
If you need to open your HP 15-g029wm to access its internal components, this guide will show you the process of removing the laptop's top plate. If you're encountering problems with your device such as overheating, freezing, random shutdowns, or needing to replace a component, you might refer to this guide. This guide can also be used if you need to remove the keyboard of your laptop.
Cosa ti serve
Unplug any charging cord or accessories connected to the device before beginning.
Remove the following Phillips screws on the lower case:
Nine 5 mm
One 6 mm
Flip the device face up and open the lid.
Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
Lift the keyboard slightly.
Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
Disconnect the keyboard ribbon cable.
Lift the keyboard off.
