Salta al contenuto principale
HP 15-g029wm Screen Replacement
Cosa ti serve
  1. HP 15-g029wm Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug any charging cord or accessories connected to the device before beginning.
  2. HP 15-g029wm Screen Replacement: passo 2, immagine 1 di 1
    • Place the laptop bottom-side up on a secure, flat surface.
  3. HP 15-g029wm Screen Replacement: passo 3, immagine 1 di 3 HP 15-g029wm Screen Replacement: passo 3, immagine 2 di 3 HP 15-g029wm Screen Replacement: passo 3, immagine 3 di 3
    • Slide each of the two switches that secure the battery to the left.
    • This will reveal an image of an unlocked lock.
  4. HP 15-g029wm Screen Replacement: passo 4, immagine 1 di 3 HP 15-g029wm Screen Replacement: passo 4, immagine 2 di 3 HP 15-g029wm Screen Replacement: passo 4, immagine 3 di 3
    • Use your hands to gently pull the disconnected battery out of the device.
    • When inserting the new battery, pay special attention to align the battery connections correctly.
  5. HP 15-g029wm Screen Replacement, Screen: passo 5, immagine 1 di 1
    • Open the laptop lid.
  6. HP 15-g029wm Screen Replacement: passo 6, immagine 1 di 2 HP 15-g029wm Screen Replacement: passo 6, immagine 2 di 2
    • Insert an opening pick beneath the display bezel.
    • While periodically prying, slide the opening pick around the perimeter of the bezel to sever the adhesive.
  7. HP 15-g029wm Screen Replacement: passo 7, immagine 1 di 1
    • Once the majority of the adhesive is severed, use an opening pick or your hands to fully remove the bezel.
  8. HP 15-g029wm Screen Replacement: passo 8, immagine 1 di 2 HP 15-g029wm Screen Replacement: passo 8, immagine 2 di 2
    • Use a Phillips screwdriver to remove the four 4 mm screws that secure the LCD panel.
  9. HP 15-g029wm Screen Replacement: passo 9, immagine 1 di 1
    • Use your hands to carefully remove/lift the panel away from the device.
    • The screen is connected to the device by a cord-do NOT pull it completely away or you risk damaging the device.
  10. HP 15-g029wm Screen Replacement: passo 10, immagine 1 di 2 HP 15-g029wm Screen Replacement: passo 10, immagine 2 di 2
    • Gently peel up the tape over the display cable.
    • If there is a hinge, flip it up.
    • Remove the display cable.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 78
