Introduzione
This is a guide on how to replace the RAM on your HP 15-g029wm. This guide may be needed if you're encountering problems with your HP 15-g029wm's screen freezing. There is only one step in this guide that describes how to remove the RAM from your motherboard to replace it.
Cosa ti serve
Unplug any charging cord or accessories connected to the device before beginning.
Remove the following Phillips screws on the lower case:
Nine 5 mm
One 6 mm
Flip the device face up and open the lid.
Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
Lift the keyboard slightly.
Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
Disconnect the keyboard ribbon cable.
Lift the keyboard off.
Use a Phillips screwdriver to remove the three 5 mm screws that secure the fan.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module
Slide the RAM module straight out of its socket.
