Salta al contenuto principale
HP 15-g029wm Fan Replacement
Cosa ti serve
  1. HP 15-g029wm Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug any charging cord or accessories connected to the device before beginning.
  2. HP 15-g029wm Fan Replacement: passo 2, immagine 1 di 1
    • Place the laptop bottom-side up on a secure, flat surface.
  3. HP 15-g029wm Fan Replacement: passo 3, immagine 1 di 3 HP 15-g029wm Fan Replacement: passo 3, immagine 2 di 3 HP 15-g029wm Fan Replacement: passo 3, immagine 3 di 3
    • Slide each of the two switches that secure the battery to the left.
    • This will reveal an image of an unlocked lock.
  4. HP 15-g029wm Fan Replacement: passo 4, immagine 1 di 3 HP 15-g029wm Fan Replacement: passo 4, immagine 2 di 3 HP 15-g029wm Fan Replacement: passo 4, immagine 3 di 3
    • Use your hands to gently pull the disconnected battery out of the device.
    • When inserting the new battery, pay special attention to align the battery connections correctly.
  5. HP 15-g029wm Fan Replacement, Upper Case: passo 5, immagine 1 di 2 HP 15-g029wm Fan Replacement, Upper Case: passo 5, immagine 2 di 2
    • Remove the following Phillips screws on the lower case:
    • Nine 5 mm
    • One 6 mm
    • This will allow the optical drive to separate from the chassis.
  6. HP 15-g029wm Fan Replacement: passo 6, immagine 1 di 1
    • Slide the optical drive directly out of its slot.
  7. HP 15-g029wm Fan Replacement: passo 7, immagine 1 di 1
    • Remove the two 2 mm Phillips screws on the lip of the optical drive slot.
  8. HP 15-g029wm Fan Replacement: passo 8, immagine 1 di 3 HP 15-g029wm Fan Replacement: passo 8, immagine 2 di 3 HP 15-g029wm Fan Replacement: passo 8, immagine 3 di 3
    • Use an opening pick to remove the two circular rubber feet near the laptop hinges.
    • Remove both of the 8 mm Phillips screws.
    • The screws were hidden by the rubber feet.
  9. HP 15-g029wm Fan Replacement: passo 9, immagine 1 di 2 HP 15-g029wm Fan Replacement: passo 9, immagine 2 di 2
    • Use an opening pick to pry up and remove the left hinge cover.
    • Use an opening pick to pry up and remove the right hinge cover.
  10. HP 15-g029wm Fan Replacement: passo 10, immagine 1 di 3 HP 15-g029wm Fan Replacement: passo 10, immagine 2 di 3 HP 15-g029wm Fan Replacement: passo 10, immagine 3 di 3
    • Flip the device face up and open the lid.
    • Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
    • Lift the keyboard slightly.
    • There is a ribbon cable connecting the keyboard to the device on the underside. Do NOT pull it away or you risk ripping the ribbon cable and causing damage.
    • Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
    • Disconnect the keyboard ribbon cable.
    • Lift the keyboard off.
  11. HP 15-g029wm Fan Replacement: passo 11, immagine 1 di 3 HP 15-g029wm Fan Replacement: passo 11, immagine 2 di 3 HP 15-g029wm Fan Replacement: passo 11, immagine 3 di 3
    • Remove two 5 mm screws using a Phillips screwdriver.
    • Insert an opening pick in the seam between the top case and chassis.
    • Slide the opening pick around the edge of the device to separate the top case from the chassis.
    • Slightly lift the top case up and away from the chassis.
    • There is a ribbon cable connecting the top plate to the device. Handle with care, and do NOT yank on the ribbon cable to prevent damage.
  12. HP 15-g029wm Fan Replacement: passo 12, immagine 1 di 3 HP 15-g029wm Fan Replacement: passo 12, immagine 2 di 3 HP 15-g029wm Fan Replacement: passo 12, immagine 3 di 3
    • Use your fingers or an opening pick to flip up the black ZIF locking flap.
    • Disconnect the ribbon cable.
    • Lift off the top case.
  13. HP 15-g029wm Fan Replacement, Fan: passo 13, immagine 1 di 2 HP 15-g029wm Fan Replacement, Fan: passo 13, immagine 2 di 2
    • Use a Phillips screwdriver to remove the three 5 mm screws that secure the fan.
  14. HP 15-g029wm Fan Replacement: passo 14, immagine 1 di 2 HP 15-g029wm Fan Replacement: passo 14, immagine 2 di 2
    • Gently "walk" the fan connector directly out of its motherboard socket.
    • Do not pull on the wires.
  15. HP 15-g029wm Fan Replacement: passo 15, immagine 1 di 1
    • Lift the fan up and out of the chassis.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 100
