Salta al contenuto principale
HP 15-g020dx Hard Drive Replacement
Cosa ti serve
  1. HP 15-g020dx Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so that the bottom is facing you.
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g020dx Hard Drive Replacement: passo 2, immagine 1 di 1
    • Place your finger on the left latch and slide it towards the center of the laptop to remove the battery.
  3. HP 15-g020dx Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the battery from the laptop.
  4. HP 15-g020dx Hard Drive Replacement, Keyboard: passo 4, immagine 1 di 1
    • Use the plastic opening tool to lift the panel with the keyboard.
  5. HP 15-g020dx Hard Drive Replacement: passo 5, immagine 1 di 1
    • Take the keyboard and the section of the panel surrounding the keyboard apart.
  6. HP 15-g020dx Hard Drive Replacement: passo 6, immagine 1 di 2 HP 15-g020dx Hard Drive Replacement: passo 6, immagine 2 di 2
    • Lift the flip covering the connection port and remove the connecting strip to detach the keyboard from the motherboard.
  7. HP 15-g020dx Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 2 HP 15-g020dx Hard Drive Replacement, Hard Drive: passo 7, immagine 2 di 2
    • Remove the two screws securing the hard drive to the device using the Phillips #0 screwdriver.
    • Warning: the hard drive and two screws are missing in the picture. The positions of screws are marked out.
  8. HP 15-g020dx Hard Drive Replacement: passo 8, immagine 1 di 1
    • Remove the hard drive from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Be really careful when removing the top case, around the keyboard because there are a couple of really cheap ribbon cables. One connects the power button, another the trackpad. I have to buy a replacement cable and power button board now because I pulled the top case off too quickly and broke the connection at the power button board.
The plastic top case around the keyboard snaps onto the lower part of the case, with many, many tabs and doesn’t even need screws to stay together. You’ll have to wrestle with it, but don’t pull it too far from the lower case.
Warren Buckley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,255
