Salta al contenuto principale
HP 15-g010dx Button Board Replacement
Cosa ti serve
  1. HP 15-g010dx Button Board Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g010dx Button Board Replacement: passo 2, immagine 1 di 1
    • Place your finger on the left latch and slide it towards the center of the laptop.
  3. HP 15-g010dx Button Board Replacement: passo 3, immagine 1 di 1
    • Pull on the battery to remove.
  4. HP 15-g010dx Button Board Replacement, Keyboard: passo 4, immagine 1 di 1
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
  5. HP 15-g010dx Button Board Replacement: passo 5, immagine 1 di 1
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
  6. HP 15-g010dx Button Board Replacement: passo 6, immagine 1 di 1
    • Using the tool of your choice, gently pry up on the top of the keyboard.
  7. HP 15-g010dx Button Board Replacement: passo 7, immagine 1 di 1
    • Release the top of the keyboard.
  8. HP 15-g010dx Button Board Replacement: passo 8, immagine 1 di 1
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
  9. HP 15-g010dx Button Board Replacement, Button Board: passo 9, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove all the 5 millimeter screws located on the bottom of the laptop.
  10. HP 15-g010dx Button Board Replacement: passo 10, immagine 1 di 1
    • Using the spudger, remove the two rubber feet that are located near the battery.
  11. HP 15-g010dx Button Board Replacement: passo 11, immagine 1 di 1
    • Now remove the two Phillips screws that are located below the rubber feet.
  12. HP 15-g010dx Button Board Replacement: passo 12, immagine 1 di 3 HP 15-g010dx Button Board Replacement: passo 12, immagine 2 di 3 HP 15-g010dx Button Board Replacement: passo 12, immagine 3 di 3
    • Remove the optical drive by pulling it out by hand.
  13. HP 15-g010dx Button Board Replacement: passo 13, immagine 1 di 1
    • Remove the two Phillips screws inside the optical drive housing.
  14. HP 15-g010dx Button Board Replacement: passo 14, immagine 1 di 1
    • Disconnect the power button ribbon cable by lifting the connector.
  15. HP 15-g010dx Button Board Replacement: passo 15, immagine 1 di 1
    • Now disconnect the touch pad ribbon cable by lifting the connector.
  16. HP 15-g010dx Button Board Replacement: passo 16, immagine 1 di 3 HP 15-g010dx Button Board Replacement: passo 16, immagine 2 di 3 HP 15-g010dx Button Board Replacement: passo 16, immagine 3 di 3
    • Remove the screws indicated by an arrow stamped into the metal.
  17. HP 15-g010dx Button Board Replacement: passo 17, immagine 1 di 1
    • Insert the spudger between the palmrest and the laptop body.
  18. HP 15-g010dx Button Board Replacement: passo 18, immagine 1 di 1
    • Lift up on palm rest, while working the spudger around the perimeter.
  19. HP 15-g010dx Button Board Replacement: passo 19, immagine 1 di 2 HP 15-g010dx Button Board Replacement: passo 19, immagine 2 di 2
    • Remove palm rest and flip it over.
  20. HP 15-g010dx Button Board Replacement: passo 20, immagine 1 di 2 HP 15-g010dx Button Board Replacement: passo 20, immagine 2 di 2
    • Release the cable connected to the button board.
  21. HP 15-g010dx Button Board Replacement: passo 21, immagine 1 di 2 HP 15-g010dx Button Board Replacement: passo 21, immagine 2 di 2
    • Remove the two Phillips screws securing the button board.
  22. HP 15-g010dx Button Board Replacement: passo 22, immagine 1 di 1
    • Remove button board.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 433
