Salta al contenuto principale
Introduzione
This guide explains how to remove the RAM chip from the HP 15-f009wm notebook computer. This could be done to either replace a malfunctioning chip or to upgrade to a larger chip.
Parti
Nessuna parte specificata.
  1. Turn laptop upside down. Flip the lock switch to the unlocked setting.
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. Flip the release switch. Once the flip is switched, the battery should pop out. Once the flip is switched, the battery should pop out.
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  3. Slide the battery out. Slide the battery out.
    • Slide the battery out.
  4. Remove the two Phillips #1 screws from the RAM panel. Remove the two Phillips #1 screws from the RAM panel. Remove the two Phillips #1 screws from the RAM panel.
    • Remove the two Phillips #1 screws from the RAM panel.
  5. Use the plastic opening tool to pop the panel off. Use the plastic opening tool to pop the panel off. Use the plastic opening tool to pop the panel off.
    • Use the plastic opening tool to pop the panel off.
  6. Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  7. Remove the RAM chip from the laptop.
    • Remove the RAM chip from the laptop.
Conclusione
Alex Birchler
Membro da: 14/02/2018
781 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G2, Nance Spring 2018 Membro di USF Tampa, Team S2-G2, Nance Spring 2018
USFT-NANCE-S18S2G2
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 163
