Introduzione
If your HP 15-ef2025nr laptop is not turning on, you want more RAM, or [insert other reason here], follow this guide to remove and replace your RAM. The RAM (or Random-Acess-Memory) allows your computer to quickly perform tasks. Having poor RAM could result in your laptop running very slowly or even not powering on.
Before following this guide, check out the troubleshooting guide, see how to remove the battery for safety reasons, and make sure your computer is not plugged in.
Cosa ti serve
Gently pry apart the two silver retention arms simultaneously.
Pull the RAM module directly out its socket.
