Introduzione
If your HP 15-ef2025nr laptop is constantly overheating, it may be time to replace the fan inside. The fan is what pulls cool air into the computer to prevent the circuits from getting too hot. Having the circuits get too hot creates problems with the laptop. Check out the troubleshooting guide for more diagnosing information. For the device, we recommend an original quality replacement part for all repairs.
Before following this guide, please make sure your computer is not hot to the touch and the computer battery is removed.
Cosa ti serve
Flip the laptop over and open the lid.
Insert an opening tool into the seam between the edge of the lower case and the chassis.
Gently pry around the entire perimeter until the lower case separates from the chassis.
Close the lid and flip the laptop back over.
Remove the lower case.
Use tweezers to pull the fan connector directly out of its motherboard socket.
