Salta al contenuto principale
HP 15-dy2702dx Fan Replacement
Cosa ti serve
  1. HP 15-dy2702dx Fan Replacement, Lower Case: passo 1, immagine 1 di 1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Fan Replacement: passo 2, immagine 1 di 1
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Fan Replacement: passo 3, immagine 1 di 2 HP 15-dy2702dx Fan Replacement: passo 3, immagine 2 di 2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Fan Replacement: passo 4, immagine 1 di 2 HP 15-dy2702dx Fan Replacement: passo 4, immagine 2 di 2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Fan Replacement: passo 5, immagine 1 di 3 HP 15-dy2702dx Fan Replacement: passo 5, immagine 2 di 3 HP 15-dy2702dx Fan Replacement: passo 5, immagine 3 di 3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Fan Replacement, Fan: passo 6, immagine 1 di 3 HP 15-dy2702dx Fan Replacement, Fan: passo 6, immagine 2 di 3 HP 15-dy2702dx Fan Replacement, Fan: passo 6, immagine 3 di 3
    • Use a Phillips #0 screwdriver to unscrew the three screws that secure the fan.
    • These screws sizes are M2x6.
  7. HP 15-dy2702dx Fan Replacement: passo 7, immagine 1 di 1
    • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
    • Alternatively, we recommend using a tool to push the connector out of its socket to avoid damaging the wires.
  8. HP 15-dy2702dx Fan Replacement: passo 8, immagine 1 di 2 HP 15-dy2702dx Fan Replacement: passo 8, immagine 2 di 2
    • Gently lift the fan to remove it from the case.
Conclusione
September Oo
Membro da: 09/07/23
397 Reputazione
4 Guide realizzate
Gateway, Team 1-4, Pee Fall 2023 Membro di Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 127
