Salta al contenuto principale
HP 15-dy2702dx Battery Replacement
Cosa ti serve
  1. HP 15-dy2702dx Battery Replacement, Lower Case: passo 1, immagine 1 di 1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Battery Replacement: passo 2, immagine 1 di 1
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Battery Replacement: passo 3, immagine 1 di 2 HP 15-dy2702dx Battery Replacement: passo 3, immagine 2 di 2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Battery Replacement: passo 4, immagine 1 di 2 HP 15-dy2702dx Battery Replacement: passo 4, immagine 2 di 2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Battery Replacement: passo 5, immagine 1 di 3 HP 15-dy2702dx Battery Replacement: passo 5, immagine 2 di 3 HP 15-dy2702dx Battery Replacement: passo 5, immagine 3 di 3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Battery Replacement, Battery: passo 6, immagine 1 di 2 HP 15-dy2702dx Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the five M2x6 screws that secure the battery with a Phillips #0 screwdriver.
  7. HP 15-dy2702dx Battery Replacement: passo 7, immagine 1 di 3 HP 15-dy2702dx Battery Replacement: passo 7, immagine 2 di 3 HP 15-dy2702dx Battery Replacement: passo 7, immagine 3 di 3
    • Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
    • Lift the battery up and out.
Conclusione
September Oo
Membro da: 09/07/23
397 Reputazione
4 Guide realizzate
Gateway, Team 1-4, Pee Fall 2023 Membro di Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 57
Tutti i Tempi: 349
