Salta al contenuto principale
HP 15-dw2065st Fan Replacement
Cosa ti serve
  1. HP 15-dw2065st Fan Replacement, Fan: passo 1, immagine 1 di 2 HP 15-dw2065st Fan Replacement, Fan: passo 1, immagine 2 di 2
    • Press the top left button to turn the laptop off.
    • Make sure the laptop is unplugged.
    • The light on the left side of the base of the laptop indicates if the laptop is on or off.
  2. HP 15-dw2065st Fan Replacement: passo 2, immagine 1 di 3 HP 15-dw2065st Fan Replacement: passo 2, immagine 2 di 3 HP 15-dw2065st Fan Replacement: passo 2, immagine 3 di 3
    • Close the screen and flip the laptop over so the backside is facing up.
    • Using a Phillips screwdriver, remove the left and right corner screws.
  3. HP 15-dw2065st Fan Replacement: passo 3, immagine 1 di 3 HP 15-dw2065st Fan Replacement: passo 3, immagine 2 di 3 HP 15-dw2065st Fan Replacement: passo 3, immagine 3 di 3
    • Use a spudger or your fingers to remove the protective padding from the top and bottom of the base and expose the screws.
    • With a Phillips screwdriver, remove the five screws from the base.
  4. HP 15-dw2065st Fan Replacement: passo 4, immagine 1 di 3 HP 15-dw2065st Fan Replacement: passo 4, immagine 2 di 3 HP 15-dw2065st Fan Replacement: passo 4, immagine 3 di 3
    • Open the screen.
    • Use a spudger to pry the palm rest assembly from the laptop.
    • Work the spudger around the perimeter to release the clips that secure the palm rest assembly.
    • Remove the palm rest assembly carefully as there are ribbon cables attached on the other side.
  5. HP 15-dw2065st Fan Replacement: passo 5, immagine 1 di 2 HP 15-dw2065st Fan Replacement: passo 5, immagine 2 di 2
    • With a Phillips screwdriver, remove the four screws securing the battery.
    • Remove the battery from the connector.
  6. HP 15-dw2065st Fan Replacement: passo 6, immagine 1 di 1
    • Use a spudger to lift the black locking flap.
    • Remove the ribbon cable.
  7. HP 15-dw2065st Fan Replacement: passo 7, immagine 1 di 3 HP 15-dw2065st Fan Replacement: passo 7, immagine 2 di 3 HP 15-dw2065st Fan Replacement: passo 7, immagine 3 di 3
    • Remove the black screw from the fan.
    • Pull the cable away from the connector in the same direction that the individual wires are running
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Remove the fan.
  8. HP 15-dw2065st Fan Replacement: passo 8, immagine 1 di 2 HP 15-dw2065st Fan Replacement: passo 8, immagine 2 di 2
    • Set the new fan in place.
    • Plug in the new fan.
    • Screw in the new fan.
    • Return all parts to the base.
    • Close the base.
Linea Traguardo
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 20
Tutti i Tempi: 268
