Salta al contenuto principale
HP 15-db0015dx USB/SD Card Reader Replacement
Cosa ti serve
  1. HP 15-db0015dx USB/SD Card Reader Replacement, Battery: passo 1, immagine 1 di 2 HP 15-db0015dx USB/SD Card Reader Replacement, Battery: passo 1, immagine 2 di 2
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx USB/SD Card Reader Replacement: passo 2, immagine 1 di 3 HP 15-db0015dx USB/SD Card Reader Replacement: passo 2, immagine 2 di 3 HP 15-db0015dx USB/SD Card Reader Replacement: passo 2, immagine 3 di 3
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx USB/SD Card Reader Replacement: passo 3, immagine 1 di 3 HP 15-db0015dx USB/SD Card Reader Replacement: passo 3, immagine 2 di 3 HP 15-db0015dx USB/SD Card Reader Replacement: passo 3, immagine 3 di 3
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: passo 4, immagine 1 di 3 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: passo 4, immagine 2 di 3 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
    • Pull the hard drive bracket out.
  5. HP 15-db0015dx USB/SD Card Reader Replacement: passo 5, immagine 1 di 1
    • Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
  6. HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: passo 6, immagine 1 di 3 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: passo 6, immagine 2 di 3 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: passo 6, immagine 3 di 3
    • Lift up on the connector pin that attaches the SD card reader to the motherboard
    • Gently pull the wire out
  7. HP 15-db0015dx USB/SD Card Reader Replacement: passo 7, immagine 1 di 2 HP 15-db0015dx USB/SD Card Reader Replacement: passo 7, immagine 2 di 2
    • Snake the wire underneath the battery support
    • Pull the wire out to allow the SD Card reader to be removed
  8. HP 15-db0015dx USB/SD Card Reader Replacement: passo 8, immagine 1 di 3 HP 15-db0015dx USB/SD Card Reader Replacement: passo 8, immagine 2 di 3 HP 15-db0015dx USB/SD Card Reader Replacement: passo 8, immagine 3 di 3
    • Remove the two Phillips #0 screws holding the SD Card reader in place.
    • Gently pull the SD card reader up and out of the slot.
    • A spudger may have to be used to pop the SD card reader out of place.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 548
