Salta al contenuto principale
HP 15-db0004dx Battery Replacement
Cosa ti serve
  1. HP 15-db0004dx Battery Replacement, Bottom Case: passo 1, immagine 1 di 2 HP 15-db0004dx Battery Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Turn the laptop off and unplug it before starting.
    • Flip your laptop over, face down.
  2. HP 15-db0004dx Battery Replacement: passo 2, immagine 1 di 1
    • Peel off the two long rubber grips running lengthwise on the laptop.
  3. HP 15-db0004dx Battery Replacement: passo 3, immagine 1 di 2 HP 15-db0004dx Battery Replacement: passo 3, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
  4. HP 15-db0004dx Battery Replacement: passo 4, immagine 1 di 1
    • Carefully slide the optical drive out of the laptop.
  5. HP 15-db0004dx Battery Replacement: passo 5, immagine 1 di 1
    • Use a plastic opening tool to separate the back panel from the laptop.
    • For an easier removal, start at the corner and run the tool along the edge of the cover.
    • If you do not have a plastic opening tool, open it carefully using your hands, as shown.
    • Be careful to not bend the back panel, or to not apply too much pressure and force, doing so could cause the panel to break.
  6. HP 15-db0004dx Battery Replacement, Battery: passo 6, immagine 1 di 2 HP 15-db0004dx Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Using the Philips #000 screwdriver remove all of the six 5mm screws.
  7. HP 15-db0004dx Battery Replacement: passo 7, immagine 1 di 3 HP 15-db0004dx Battery Replacement: passo 7, immagine 2 di 3 HP 15-db0004dx Battery Replacement: passo 7, immagine 3 di 3
    • Disconnect the battery connector.
    • Slide the battery up and out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 653
