Salta al contenuto principale
HP 15-da0002dx Fan Replacement
Cosa ti serve
  1. HP 15-da0002dx Fan Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Fan Replacement: passo 2, immagine 1 di 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Fan Replacement: passo 3, immagine 1 di 2 HP 15-da0002dx Fan Replacement: passo 3, immagine 2 di 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Fan Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Fan Replacement: passo 5, immagine 1 di 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Fan Replacement: passo 6, immagine 1 di 2 HP 15-da0002dx Fan Replacement: passo 6, immagine 2 di 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Fan Replacement: passo 7, immagine 1 di 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx Fan Replacement, Battery: passo 8, immagine 1 di 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx Fan Replacement: passo 9, immagine 1 di 2 HP 15-da0002dx Fan Replacement: passo 9, immagine 2 di 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx Fan Replacement, Fan: passo 10, immagine 1 di 2 HP 15-da0002dx Fan Replacement, Fan: passo 10, immagine 2 di 2
    • Hold the fan in place and remove the one 8.0 mm screw from the fan .
  11. HP 15-da0002dx Fan Replacement: passo 11, immagine 1 di 1
    • Pull out the connector for the fan cable using the opening tool or spudger.
  12. HP 15-da0002dx Fan Replacement: passo 12, immagine 1 di 1
    • Carefully take out the fan from the computer.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,511
