Salta al contenuto principale
HP 15-da0002dx Back Cover Replacement
Cosa ti serve
  1. HP 15-da0002dx Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Back Cover Replacement: passo 2, immagine 1 di 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Back Cover Replacement: passo 3, immagine 1 di 2 HP 15-da0002dx Back Cover Replacement: passo 3, immagine 2 di 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Back Cover Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Back Cover Replacement: passo 5, immagine 1 di 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Back Cover Replacement: passo 6, immagine 1 di 2 HP 15-da0002dx Back Cover Replacement: passo 6, immagine 2 di 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Back Cover Replacement: passo 7, immagine 1 di 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 44
Tutti i Tempi: 6,095
