Salta al contenuto principale
HP 15-d076nr Wireless Card Replacement
Cosa ti serve
  1. HP 15-d076nr Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
  2. HP 15-d076nr Wireless Card Replacement: passo 2, immagine 1 di 1
    • Move the right switch to the left so that the orange unlock symbol is showing.
  3. HP 15-d076nr Wireless Card Replacement: passo 3, immagine 1 di 1
    • Move the left switch to the right, covering the battery symbol, and hold.
  4. HP 15-d076nr Wireless Card Replacement: passo 4, immagine 1 di 1
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
  5. HP 15-d076nr Wireless Card Replacement, Wireless Card: passo 5, immagine 1 di 1
    • Re-orient the laptop, so that the back of the laptop faces away from you.
  6. HP 15-d076nr Wireless Card Replacement: passo 6, immagine 1 di 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
  7. HP 15-d076nr Wireless Card Replacement: passo 7, immagine 1 di 2 HP 15-d076nr Wireless Card Replacement: passo 7, immagine 2 di 2
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
  8. HP 15-d076nr Wireless Card Replacement: passo 8, immagine 1 di 2 HP 15-d076nr Wireless Card Replacement: passo 8, immagine 2 di 2
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
  9. HP 15-d076nr Wireless Card Replacement: passo 9, immagine 1 di 3 HP 15-d076nr Wireless Card Replacement: passo 9, immagine 2 di 3 HP 15-d076nr Wireless Card Replacement: passo 9, immagine 3 di 3
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
  10. HP 15-d076nr Wireless Card Replacement: passo 10, immagine 1 di 1
    • Slide the wireless card to the left to remove it from the socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 566
