Salta al contenuto principale
HP 15-d076nr Battery Replacement
  1. HP 15-d076nr Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
  2. HP 15-d076nr Battery Replacement: passo 2, immagine 1 di 1
    • Move the right switch to the left so that the orange unlock symbol is showing.
  3. HP 15-d076nr Battery Replacement: passo 3, immagine 1 di 1
    • Move the left switch to the right, covering the battery symbol, and hold.
  4. HP 15-d076nr Battery Replacement: passo 4, immagine 1 di 1
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 767
