Salta al contenuto principale
HP 15-ba0709dx Speakers Replacement
Cosa ti serve
  1. HP 15-ba0709dx Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch on the left and right side until the battery is detached from its slot.
    • A noticeable pop will be heard when the battery is fully released.
  2. HP 15-ba0709dx Speakers Replacement: passo 2, immagine 1 di 1
    • Pull the battery out of its slot.
    • Be careful not to damage any of the connectors in the process.
  3. HP 15-ba0709dx Speakers Replacement, Back Cover: passo 3, immagine 1 di 1
    • Place the laptop on a clean, flat surface with the bottom side facing up.
  4. HP 15-ba0709dx Speakers Replacement: passo 4, immagine 1 di 1
    • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
    • Note: Make sure to keep track of the screws once they have been removed.
  5. HP 15-ba0709dx Speakers Replacement: passo 5, immagine 1 di 1
    • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
    • Note:Place these newly removed screws with the ones removed in Step 2.
  6. HP 15-ba0709dx Speakers Replacement: passo 6, immagine 1 di 2 HP 15-ba0709dx Speakers Replacement: passo 6, immagine 2 di 2
    • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
    • Removing the friction pads will reveal two more anchoring screws.
    • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
  7. HP 15-ba0709dx Speakers Replacement: passo 7, immagine 1 di 1
    • Remove disc reader.
    • Note: If all screws are removed it should slide out easily.
  8. HP 15-ba0709dx Speakers Replacement: passo 8, immagine 1 di 2 HP 15-ba0709dx Speakers Replacement: passo 8, immagine 2 di 2
    • Use a plastic prod to pry the back cover off the laptop.
    • Be careful not to damage the laptop while prying.
  9. HP 15-ba0709dx Speakers Replacement, Speakers: passo 9, immagine 1 di 2 HP 15-ba0709dx Speakers Replacement, Speakers: passo 9, immagine 2 di 2
    • Locate the speakers on the right and left on the bottom on the back of the device.
  10. HP 15-ba0709dx Speakers Replacement: passo 10, immagine 1 di 1
    • Pull up on the left speaker to pop it off.
    • Do the same on the right speaker to pop it off.
  11. HP 15-ba0709dx Speakers Replacement: passo 11, immagine 1 di 2 HP 15-ba0709dx Speakers Replacement: passo 11, immagine 2 di 2
    • Pull out the speaker outlet.
    • Caution: Be careful not to damage cords while doing so.
Conclusione
Reece Marr
Membro da: 03/20/17
369 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 340
