Introduzione
Use this guide to replace a dead hard drive.
Cosa ti serve
Use Latch on the left to unlock the battery
Use Latch on the right to eject the battery
Remove the screws located beneath both rubber feet.
Two 8mm Phillips #1
Remove screws securing the hard drive bracket
Three 3mm Phillips #0
Use spudger to loosen the SATA connector then disconnect the cable and remove the hard drive.
Remove bracket screws from the hard drive.
Four 3mm Phillips #1
