Salta al contenuto principale
HP 15-ay091ms RAM Replacement
Cosa ti serve
  1. HP 15-ay091ms RAM Replacement, Battery: passo 1, immagine 1 di 2 HP 15-ay091ms RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure the device is powered off and is disconnected from any AC power supply.
    • Push the latches on either side of the battery down and outward.
    • This unlatches the battery allowing for easy removal.
    • Remove the battery.
  2. HP 15-ay091ms RAM Replacement, Back Panel: passo 2, immagine 1 di 3 HP 15-ay091ms RAM Replacement, Back Panel: passo 2, immagine 2 di 3 HP 15-ay091ms RAM Replacement, Back Panel: passo 2, immagine 3 di 3
    • Remove the screws from the bottom panel using a JIS #0 screwdriver.
    • Use the iFixit opening pick to lift the back cover from the device.
    • It is helpful to get an opening in one spot of the back cover and carry that opening around the device.
  3. HP 15-ay091ms RAM Replacement, RAM: passo 3, immagine 1 di 3 HP 15-ay091ms RAM Replacement, RAM: passo 3, immagine 2 di 3 HP 15-ay091ms RAM Replacement, RAM: passo 3, immagine 3 di 3
    • Pull the metal brackets holding the RAM in place away from each other.
    • After you hold the brackets apart, the RAM will pop up.
    • Remove the RAM.
Conclusione
Gabriel
Membro da: 09/07/23
145 Reputazione
2 Guide realizzate
Gateway, Team A-1, Gonzalez Fall 2023 Membro di Gateway, Team A-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23SAG1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 75
