Salta al contenuto principale
HP 15-ay014dx Hard Drive Disk Replacement
Cosa ti serve
  1. HP 15-ay014dx Hard Drive Disk Replacement, Battery: passo 1, immagine 1 di 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Hard Drive Disk Replacement: passo 2, immagine 1 di 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Hard Drive Disk Replacement: passo 3, immagine 1 di 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Hard Drive Disk Replacement, Optical Drive: passo 4, immagine 1 di 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Hard Drive Disk Replacement: passo 5, immagine 1 di 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: passo 6, immagine 1 di 2 HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: passo 6, immagine 2 di 2
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Hard Drive Disk Replacement: passo 7, immagine 1 di 3 HP 15-ay014dx Hard Drive Disk Replacement: passo 7, immagine 2 di 3 HP 15-ay014dx Hard Drive Disk Replacement: passo 7, immagine 3 di 3
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  8. HP 15-ay014dx Hard Drive Disk Replacement: passo 8, immagine 1 di 3 HP 15-ay014dx Hard Drive Disk Replacement: passo 8, immagine 2 di 3 HP 15-ay014dx Hard Drive Disk Replacement: passo 8, immagine 3 di 3
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  9. HP 15-ay014dx Hard Drive Disk Replacement: passo 9, immagine 1 di 2 HP 15-ay014dx Hard Drive Disk Replacement: passo 9, immagine 2 di 2
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  10. HP 15-ay014dx Hard Drive Disk Replacement: passo 10, immagine 1 di 1
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
Conclusione
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,929
