Salta al contenuto principale
HP 15-ay014dx Battery Replacement
  1. HP 15-ay014dx Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Battery Replacement: passo 2, immagine 1 di 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Battery Replacement: passo 3, immagine 1 di 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
Conclusione
To reassemble your device, follow these steps in reverse order.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 768
