Salta al contenuto principale
HP 15-ay011nr Fan Replacement
Cosa ti serve
  1. HP 15-ay011nr Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the two battery lock latches on the back of the device to the “unlock” position.
  2. HP 15-ay011nr Fan Replacement: passo 2, immagine 1 di 1
    • Lift the battery upward to remove it from the device.
  3. HP 15-ay011nr Fan Replacement, Back Panel: passo 3, immagine 1 di 1
    • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
    • There should be 10 in total, be sure to keep them together!
  4. HP 15-ay011nr Fan Replacement: passo 4, immagine 1 di 1
    • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
  5. HP 15-ay011nr Fan Replacement: passo 5, immagine 1 di 2 HP 15-ay011nr Fan Replacement: passo 5, immagine 2 di 2
    • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
    • Place the adhesive side up as you will need to place them back after your replacement is complete.
  6. HP 15-ay011nr Fan Replacement: passo 6, immagine 1 di 2 HP 15-ay011nr Fan Replacement: passo 6, immagine 2 di 2
    • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
    • Be sure to keep the screws together!
  7. HP 15-ay011nr Fan Replacement: passo 7, immagine 1 di 1
    • Carefully remove the back panel from the device.
    • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
  8. HP 15-ay011nr Fan Replacement, Fan: passo 8, immagine 1 di 2 HP 15-ay011nr Fan Replacement, Fan: passo 8, immagine 2 di 2
    • There are two 5/16 in. screws adjacent from each other that secure the fan to the device. Use the PH1 phillips-head screwdriver to remove them.
    • Be sure to keep them together!
  9. HP 15-ay011nr Fan Replacement: passo 9, immagine 1 di 2 HP 15-ay011nr Fan Replacement: passo 9, immagine 2 di 2
    • Lift the clear plastic strip holding down the fan and lift the fan out of place.
  10. HP 15-ay011nr Fan Replacement: passo 10, immagine 1 di 2 HP 15-ay011nr Fan Replacement: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use your fingers or tweezers to pinch both sides of the connector and remove the fan from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,463
