Salta al contenuto principale
HP 15-af013cl Motherboard Replacement
Cosa ti serve
  1. HP 15-af013cl Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Motherboard Replacement: passo 2, immagine 1 di 3 HP 15-af013cl Motherboard Replacement: passo 2, immagine 2 di 3 HP 15-af013cl Motherboard Replacement: passo 2, immagine 3 di 3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl Motherboard Replacement: passo 4, immagine 1 di 2 HP 15-af013cl Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl Motherboard Replacement: passo 5, immagine 1 di 1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  6. HP 15-af013cl Motherboard Replacement: passo 6, immagine 1 di 2 HP 15-af013cl Motherboard Replacement: passo 6, immagine 2 di 2
    • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
    • Disconnect the fan connector from the motherboard.
  7. HP 15-af013cl Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
  8. HP 15-af013cl Motherboard Replacement: passo 8, immagine 1 di 3 HP 15-af013cl Motherboard Replacement: passo 8, immagine 2 di 3 HP 15-af013cl Motherboard Replacement: passo 8, immagine 3 di 3
    • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
    • Remove the Wi-Fi card and cables.
  9. HP 15-af013cl Motherboard Replacement: passo 9, immagine 1 di 1
    • Carefully lift out the motherboard from the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S8-G6, Banghart Fall 2017 Membro di Cal Poly, Team S8-G6, Banghart Fall 2017
CPSU-BANGHART-F17S8G6
5 Membri
6 Guide realizzate
Un commento
i need motherboard hp model:15-bs127ne
elbetel ashenafi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,017
