Salta al contenuto principale
HP 15-ac142dx Motherboard Battery Replacement
Cosa ti serve
  1. HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: passo 1, immagine 1 di 3 HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: passo 1, immagine 2 di 3 HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: passo 1, immagine 3 di 3
    • Turn off the computer and flip it over onto a flat surface.
    • Remove battery by sliding the battery lock.
    • Remove the 10 screws
  2. HP 15-ac142dx Motherboard Battery Replacement: passo 2, immagine 1 di 2 HP 15-ac142dx Motherboard Battery Replacement: passo 2, immagine 2 di 2
    • Flip the computer back over and use the iFixit tool in order to pry the keyboard from the bottom of the computer.
    • Once off you will be able to see the mother board battery.
    • Remove the battery.
    • The battery should be able to be easily removed just by hand
Conclusione
Follow previous instructions in reverse order to reassemble the device .
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 766
