Salta al contenuto principale
HP 15-ac121dx Screen Replacement
Cosa ti serve
  1. HP 15-ac121dx Screen  Replacement, Battery: passo 1, immagine 1 di 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Screen  Replacement: passo 2, immagine 1 di 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Screen  Replacement: passo 3, immagine 1 di 2 HP 15-ac121dx Screen  Replacement: passo 3, immagine 2 di 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Screen  Replacement: passo 4, immagine 1 di 2 HP 15-ac121dx Screen  Replacement: passo 4, immagine 2 di 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Screen  Replacement, Screen: passo 5, immagine 1 di 1
    • Open the laptop so that the screen is facing you.
  6. HP 15-ac121dx Screen  Replacement: passo 6, immagine 1 di 2 HP 15-ac121dx Screen  Replacement: passo 6, immagine 2 di 2
    • With the screen facing you, use the plastic opening tool to remove the liner around the screen
  7. HP 15-ac121dx Screen  Replacement: passo 7, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove all four 2mm screws in each corner of the screen.
  8. HP 15-ac121dx Screen  Replacement: passo 8, immagine 1 di 2 HP 15-ac121dx Screen  Replacement: passo 8, immagine 2 di 2
    • Carefully remove the screen and place it face down on the keyboard.
    • Do not pull the screen away from the front panel assembly, as this would damage the cord connecting the screen to the front panel assembly.
  9. HP 15-ac121dx Screen  Replacement: passo 9, immagine 1 di 2 HP 15-ac121dx Screen  Replacement: passo 9, immagine 2 di 2
    • With the screen faced down on the keyboard, remove the grounding tape adhered to the back of the screen.
    • You should see a 36-pin plug underneath the grounding tape.
    • Carefully remove the 36-pin plug, not to damage the grounding tape or the plug.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 725
