Salta al contenuto principale
HP 15-ac121dx RAM Replacement
Cosa ti serve
  1. HP 15-ac121dx RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx RAM Replacement: passo 2, immagine 1 di 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx RAM Replacement: passo 3, immagine 1 di 2 HP 15-ac121dx RAM Replacement: passo 3, immagine 2 di 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx RAM Replacement: passo 4, immagine 1 di 2 HP 15-ac121dx RAM Replacement: passo 4, immagine 2 di 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx RAM Replacement, Back Panel: passo 5, immagine 1 di 2 HP 15-ac121dx RAM Replacement, Back Panel: passo 5, immagine 2 di 2
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. HP 15-ac121dx RAM Replacement: passo 6, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. HP 15-ac121dx RAM Replacement: passo 7, immagine 1 di 1
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
  8. HP 15-ac121dx RAM Replacement, RAM: passo 8, immagine 1 di 1
    • With the back panel removed, orient the laptop with the fan located in the bottom left corner.
    • Locate the RAM card.
  9. HP 15-ac121dx RAM Replacement: passo 9, immagine 1 di 2 HP 15-ac121dx RAM Replacement: passo 9, immagine 2 di 2
    • Using your fingers, carefully release the locking devices on both sides of the RAM card by moving them away from each other.
    • The RAM card will pop up to sit at an angle.
    • Carefully remove the RAM card with the same orientation which it sits.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 588
