Salta al contenuto principale
HP 15-ac121dx Fan Replacement
Cosa ti serve
  1. HP 15-ac121dx Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Fan Replacement: passo 2, immagine 1 di 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Fan Replacement: passo 3, immagine 1 di 2 HP 15-ac121dx Fan Replacement: passo 3, immagine 2 di 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Fan Replacement: passo 4, immagine 1 di 2 HP 15-ac121dx Fan Replacement: passo 4, immagine 2 di 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Fan Replacement, Back Panel: passo 5, immagine 1 di 3 HP 15-ac121dx Fan Replacement, Back Panel: passo 5, immagine 2 di 3 HP 15-ac121dx Fan Replacement, Back Panel: passo 5, immagine 3 di 3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx Fan Replacement: passo 6, immagine 1 di 1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx Fan Replacement: passo 7, immagine 1 di 3 HP 15-ac121dx Fan Replacement: passo 7, immagine 2 di 3 HP 15-ac121dx Fan Replacement: passo 7, immagine 3 di 3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx Fan Replacement, Fan: passo 8, immagine 1 di 3 HP 15-ac121dx Fan Replacement, Fan: passo 8, immagine 2 di 3 HP 15-ac121dx Fan Replacement, Fan: passo 8, immagine 3 di 3
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  9. HP 15-ac121dx Fan Replacement: passo 9, immagine 1 di 2 HP 15-ac121dx Fan Replacement: passo 9, immagine 2 di 2
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  10. HP 15-ac121dx Fan Replacement: passo 10, immagine 1 di 2 HP 15-ac121dx Fan Replacement: passo 10, immagine 2 di 2
    • Remove fan.
    • Unscrew the two screws holding in the fan.
Conclusione
Replace fan. To reassemble your device, follow these instructions in reverse order.
Onose Aigbe
Membro da: 01/30/18
390 Reputazione
3 Guide realizzate
Baylor, Team S1-G2, Johnson Spring 2018 Membro di Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,290
