Introduzione
If the computer won't load past the startup screen or randomly crashes during normal operation, there isn't enough RAM or the RAM is damaged and needs replacement.
Cosa ti serve
Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
Slide the battery out as shown in the picture.
Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
Locate the two corner grips on the hinge side of the computer.
Using a metal spudger, remove the two corner grips to reveal the screws.
Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
To disconnect the ribbon connector, flip up the black clip shown in the picture.
Gently pull the ribbon until disconnected.
Remove the 2 black screws holding the hard drive to the computer frame.
Altre 4 persone hanno completato questa guida.
