Introduzione
If the computer will not boot upon start-up but shows BIOS dialog, the component in suspect is the hard drive. In this case, the hard drive is faulty or broken and needs replacement.
Cosa ti serve
Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
Slide the battery out as shown in the picture.
Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
Locate the two corner grips on the hinge side of the computer.
Using a metal spudger, remove the two corner grips to reveal the screws.
Remove the 2 black screws holding the hard drive to the computer frame.
Altre 2 persone hanno completato questa guida.
