Salta al contenuto principale
HP 15-R263DX Disassembly
Cosa ti serve
  1. HP 15-R263DX Disassembly, Battery: passo 1, immagine 1 di 2 HP 15-R263DX Disassembly, Battery: passo 1, immagine 2 di 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
  2. HP 15-R263DX Disassembly, Optical Drive: passo 2, immagine 1 di 2 HP 15-R263DX Disassembly, Optical Drive: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
  3. HP 15-R263DX Disassembly: passo 3, immagine 1 di 1
    • Gently slide the optical drive out of the side of the computer.
  4. HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: passo 4, immagine 1 di 2 HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: passo 4, immagine 2 di 2
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
  5. HP 15-R263DX Disassembly: passo 5, immagine 1 di 1
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
  6. HP 15-R263DX Disassembly: passo 6, immagine 1 di 1
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
  7. HP 15-R263DX Disassembly: passo 7, immagine 1 di 2 HP 15-R263DX Disassembly: passo 7, immagine 2 di 2
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
  8. HP 15-R263DX Disassembly: passo 8, immagine 1 di 2 HP 15-R263DX Disassembly: passo 8, immagine 2 di 2
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
  9. HP 15-R263DX Disassembly: passo 9, immagine 1 di 1
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
Conclusione
Altre 10 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 34
Tutti i Tempi: 6,319
