Salta al contenuto principale
HP 15-BA078DX Back Panel Replacement
Cosa ti serve
  1. HP 15-BA078DX Back Panel Replacement, Battery: passo 1, immagine 1 di 3 HP 15-BA078DX Back Panel Replacement, Battery: passo 1, immagine 2 di 3 HP 15-BA078DX Back Panel Replacement, Battery: passo 1, immagine 3 di 3
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
  2. HP 15-BA078DX Back Panel Replacement, Disc Drive: passo 2, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
  3. HP 15-BA078DX Back Panel Replacement: passo 3, immagine 1 di 3 HP 15-BA078DX Back Panel Replacement: passo 3, immagine 2 di 3 HP 15-BA078DX Back Panel Replacement: passo 3, immagine 3 di 3
    • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
  4. HP 15-BA078DX Back Panel Replacement, Back Panel: passo 4, immagine 1 di 1
    • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remember to remove the two screws under the rubber feet.
  5. HP 15-BA078DX Back Panel Replacement: passo 5, immagine 1 di 3 HP 15-BA078DX Back Panel Replacement: passo 5, immagine 2 di 3 HP 15-BA078DX Back Panel Replacement: passo 5, immagine 3 di 3
    • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
    • You may need to flip the laptop over to unlatch all of the internal clips.
  6. HP 15-BA078DX Back Panel Replacement: passo 6, immagine 1 di 3 HP 15-BA078DX Back Panel Replacement: passo 6, immagine 2 di 3 HP 15-BA078DX Back Panel Replacement: passo 6, immagine 3 di 3
    • Carefully pull the shell of the computer apart.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Thank you so much! I know I am probably the only or one of the few people to write a comment for this specific laptop but I wanted to upgrade the RAM and HDD to SSD. Have a great day
Swag kitty - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 693
