Salta al contenuto principale
HP 15-AF131DX Trackpad Button Circuit Board Replacement
Cosa ti serve
  1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: passo 1, immagine 1 di 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: passo 2, immagine 1 di 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: passo 2, immagine 2 di 2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 3, immagine 1 di 1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 4, immagine 1 di 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 4, immagine 2 di 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 4, immagine 3 di 3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: passo 5, immagine 1 di 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: passo 5, immagine 2 di 2
    • Remove two rubber feet by peeling them off.
    • Remove twelve Phillips head 8.8mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 6, immagine 1 di 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 6, immagine 2 di 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 6, immagine 3 di 3
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The Trackpad Button Circuit Board is found in the red box.
  7. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 7, immagine 1 di 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 7, immagine 2 di 2
    • Remove the two 3.3mm Phillips-head screws that secure the trackpad circuit board to the top cover.
  8. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 8, immagine 1 di 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift the plastic wire lock bracket.
    • Pull on the blue tab to remove the wire using the tweezers tool to make sure there is no damage as you pull.
  9. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 9, immagine 1 di 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 9, immagine 2 di 2
    • Lift the second plastic wire lock bracket.
    • Pull on the purple tab using tweezers to remove the wire.
  10. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 10, immagine 1 di 1
    • Lift and remove the trackpad button circuit board.
Conclusione
Adrianna
Membro da: 11/01/18
133 Reputazione
1 Guida realizzata
IUPUI, Team S2-G2, Harley Fall 2018 Membro di IUPUI, Team S2-G2, Harley Fall 2018
IUPUI-HARLEY-F18S2G2
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 358
