Salta al contenuto principale
HP 15-AF131DX Speaker Replacement
Cosa ti serve
  1. HP 15-AF131DX Speaker Replacement, Speakers: passo 1, immagine 1 di 2 HP 15-AF131DX Speaker Replacement, Speakers: passo 1, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Speaker Replacement: passo 2, immagine 1 di 2 HP 15-AF131DX Speaker Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the speakers.
  3. HP 15-AF131DX Speaker Replacement: passo 3, immagine 1 di 3 HP 15-AF131DX Speaker Replacement: passo 3, immagine 2 di 3 HP 15-AF131DX Speaker Replacement: passo 3, immagine 3 di 3
    • Pull up on each individual speaker, removing the rubber holds from their plastic pins.
    • Unplug the wire that connects the speakers.
    • Carefully remove the speakers from their plastic holds.
Conclusione
Cal Poly, Team S6-G2, Banghart Fall 2017 Membro di Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 635
