Salta al contenuto principale
HP 15-AF131DX Optical Drive Replacement
Cosa ti serve
  1. HP 15-AF131DX Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 2 HP 15-AF131DX Optical Drive Replacement, Optical Drive: passo 1, immagine 2 di 2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  2. HP 15-AF131DX Optical Drive Replacement: passo 2, immagine 1 di 1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  3. HP 15-AF131DX Optical Drive Replacement: passo 3, immagine 1 di 3 HP 15-AF131DX Optical Drive Replacement: passo 3, immagine 2 di 3 HP 15-AF131DX Optical Drive Replacement: passo 3, immagine 3 di 3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
Conclusione
Cal Poly, Team S6-G2, Banghart Fall 2017 Membro di Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 472
