Salta al contenuto principale
HP 14-fq1025nr Keyboard Replacement
Cosa ti serve
  1. HP 14-fq1025nr Keyboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Keyboard Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Keyboard Replacement: passo 4, immagine 1 di 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Keyboard Replacement: passo 5, immagine 1 di 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Keyboard Replacement, Battery: passo 6, immagine 1 di 2 HP 14-fq1025nr Keyboard Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Keyboard Replacement: passo 7, immagine 1 di 1
    • Remove the battery.
  8. HP 14-fq1025nr Keyboard Replacement, Fan: passo 8, immagine 1 di 1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  9. HP 14-fq1025nr Keyboard Replacement: passo 9, immagine 1 di 1
    Compra
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  10. HP 14-fq1025nr Keyboard Replacement: passo 10, immagine 1 di 1
    • Remove the fan.
  11. HP 14-fq1025nr Keyboard Replacement, Heat Sink: passo 11, immagine 1 di 1
    • Remove the four gray 3 mm screws around the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  12. HP 14-fq1025nr Keyboard Replacement, Speakers: passo 12, immagine 1 di 2 HP 14-fq1025nr Keyboard Replacement, Speakers: passo 12, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the three black 5 mm screws holding down the speaker:
    • Two screws on the left side
    • One screw on the right side
  13. HP 14-fq1025nr Keyboard Replacement: passo 13, immagine 1 di 1
    Compra
    • Unplug the speaker wire.
    • Use tweezers if needed.
  14. HP 14-fq1025nr Keyboard Replacement: passo 14, immagine 1 di 1
    • Remove the speaker.
  15. HP 14-fq1025nr Keyboard Replacement, SSD: passo 15, immagine 1 di 1
    • Remove the single 6 mm screw holding down the SSD using a Phillips #0 screwdriver.
  16. HP 14-fq1025nr Keyboard Replacement: passo 16, immagine 1 di 1
    • Slide the SSD out of the slot.
  17. HP 14-fq1025nr Keyboard Replacement, Motherboard: passo 17, immagine 1 di 3 HP 14-fq1025nr Keyboard Replacement, Motherboard: passo 17, immagine 2 di 3 HP 14-fq1025nr Keyboard Replacement, Motherboard: passo 17, immagine 3 di 3
    • Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
  18. HP 14-fq1025nr Keyboard Replacement: passo 18, immagine 1 di 2 HP 14-fq1025nr Keyboard Replacement: passo 18, immagine 2 di 2
    Compra
    • Unplug the wire connections.
  19. HP 14-fq1025nr Keyboard Replacement: passo 19, immagine 1 di 1
    • Remove the motherboard.
    • Use the iFixit opening tool to pry it out if needed.
  20. HP 14-fq1025nr Keyboard Replacement, Screen: passo 20, immagine 1 di 3 HP 14-fq1025nr Keyboard Replacement, Screen: passo 20, immagine 2 di 3 HP 14-fq1025nr Keyboard Replacement, Screen: passo 20, immagine 3 di 3
    • Remove the four black 5 mm screws holding down the two silver screen hinges using a Phillips #00 screwdriver.
  21. HP 14-fq1025nr Keyboard Replacement: passo 21, immagine 1 di 2 HP 14-fq1025nr Keyboard Replacement: passo 21, immagine 2 di 2
    • Unplug the screen from the motherboard by lifting the wire cover and removing the screen cord.
    • Separate the hinges from the computer.
  22. HP 14-fq1025nr Keyboard Replacement: passo 22, immagine 1 di 1
    • Remove the screen.
  23. HP 14-fq1025nr Keyboard Replacement, Keyboard: passo 23, immagine 1 di 1
    • Use an iFixit opening tool to remove all the plastic hold downs from the keyboard cover.
  24. HP 14-fq1025nr Keyboard Replacement: passo 24, immagine 1 di 1
    • Remove all remaining plastic hold downs on the main keyboard with an iFixit opening tool.
  25. HP 14-fq1025nr Keyboard Replacement: passo 25, immagine 1 di 1
    • Push the keyboard out of the computer.
    • During reassembly, make sure that the keyboard is tightened properly.
Conclusione
Yasli Kanimba Murenzi
Membro da: 09/27/22
193 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 25
Tutti i Tempi: 212
