Salta al contenuto principale
HP 14-ac151nr DC Power Jack Replacement
Cosa ti serve
  1. HP 14-ac151nr DC Power Jack Replacement, Backplate: passo 1, immagine 1 di 1
    • Remove battery by pushing the two buttons inward.
  2. HP 14-ac151nr DC Power Jack Replacement: passo 2, immagine 1 di 1
    • Remove the two rubber feet next to the battery.
  3. HP 14-ac151nr DC Power Jack Replacement: passo 3, immagine 1 di 1
    • Remove all 14 Phillips head #0 screws.
  4. HP 14-ac151nr DC Power Jack Replacement: passo 4, immagine 1 di 1
    • Use a plastic opener tool to pry off the black backplate.
  5. HP 14-ac151nr DC Power Jack Replacement, DC Power Jack: passo 5, immagine 1 di 2 HP 14-ac151nr DC Power Jack Replacement, DC Power Jack: passo 5, immagine 2 di 2
    • Remove the black tape near the power jack.
    • Remove the screws connecting monitor to the bottom of the computer.
  6. HP 14-ac151nr DC Power Jack Replacement: passo 6, immagine 1 di 1
    • Position the metal fittings attached to the monitor out of the way.
    • The monitor is still attached by wires — be careful not to pull on it too hard.
  7. HP 14-ac151nr DC Power Jack Replacement: passo 7, immagine 1 di 3 HP 14-ac151nr DC Power Jack Replacement: passo 7, immagine 2 di 3 HP 14-ac151nr DC Power Jack Replacement: passo 7, immagine 3 di 3
    • Disconnect the power jack from the motherboard.
    • Remove the power jack by lifting it up.
    • An opener tool may make this easier.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 438
