Salta al contenuto principale
HP 10 2101 Speaker Replacement
Cosa ti serve
  1. HP 10 2101 Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Identify the SD card port.
  2. HP 10 2101 Speaker Replacement: passo 2, immagine 1 di 1
    • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
  3. HP 10 2101 Speaker Replacement: passo 3, immagine 1 di 1
    • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
  4. HP 10 2101 Speaker Replacement: passo 4, immagine 1 di 1
    • Separate the back panel from the rest of the device.
  5. HP 10 2101 Speaker Replacement, Speakers: passo 5, immagine 1 di 1
    • Remove the pieces of black tape that hold the speaker wires to the battery.
  6. HP 10 2101 Speaker Replacement: passo 6, immagine 1 di 2 HP 10 2101 Speaker Replacement: passo 6, immagine 2 di 2
    • Use the Phillips #00 screwdriver to remove the 4mm screws from the speaker.
    • There are two screws holding both speakers to the plastic device frame.
  7. HP 10 2101 Speaker Replacement: passo 7, immagine 1 di 1
    • Desolder the speaker wires from the motherboard.
  8. HP 10 2101 Speaker Replacement: passo 8, immagine 1 di 1
    • Separate the speakers from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 180
