Salta al contenuto principale
HP 10 2101 Back Panel Replacement
Cosa ti serve
  1. HP 10 2101 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Identify the SD card port.
  2. HP 10 2101 Back Panel Replacement: passo 2, immagine 1 di 1
    • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
  3. HP 10 2101 Back Panel Replacement: passo 3, immagine 1 di 1
    • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
  4. HP 10 2101 Back Panel Replacement: passo 4, immagine 1 di 1
    • Separate the back panel from the rest of the device.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 59
Tutti i Tempi: 644
