Salta al contenuto principale
HMDX Jam Plus Speaker Replacement
Cosa ti serve
  1. HMDX Jam Plus Speaker Replacement, Battery: passo 1, immagine 1 di 3 HMDX Jam Plus Speaker Replacement, Battery: passo 1, immagine 2 di 3 HMDX Jam Plus Speaker Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Speaker Replacement: passo 2, immagine 1 di 2 HMDX Jam Plus Speaker Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Speaker Replacement: passo 3, immagine 1 di 2 HMDX Jam Plus Speaker Replacement: passo 3, immagine 2 di 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Speaker Replacement: passo 4, immagine 1 di 3 HMDX Jam Plus Speaker Replacement: passo 4, immagine 2 di 3 HMDX Jam Plus Speaker Replacement: passo 4, immagine 3 di 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Speaker Replacement: passo 5, immagine 1 di 3 HMDX Jam Plus Speaker Replacement: passo 5, immagine 2 di 3 HMDX Jam Plus Speaker Replacement: passo 5, immagine 3 di 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Speaker Replacement: passo 6, immagine 1 di 2 HMDX Jam Plus Speaker Replacement: passo 6, immagine 2 di 2
    • Use new adhesive to secure battery back to the rest of the device.
  7. HMDX Jam Plus Speaker Replacement, Speaker: passo 7, immagine 1 di 2 HMDX Jam Plus Speaker Replacement, Speaker: passo 7, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from device.
  8. HMDX Jam Plus Speaker Replacement: passo 8, immagine 1 di 1
    • Use the plastic opening tool to pry the glue away from the wire. Be careful not to damage the wire.
  9. HMDX Jam Plus Speaker Replacement: passo 9, immagine 1 di 2 HMDX Jam Plus Speaker Replacement: passo 9, immagine 2 di 2
    • Use the plastic opening tool to separate the center plastic piece from the rest of the device.
    • Gently lift the center plastic piece and feed the speaker wire through the hole.
  10. HMDX Jam Plus Speaker Replacement: passo 10, immagine 1 di 2 HMDX Jam Plus Speaker Replacement: passo 10, immagine 2 di 2
    • Use the plastic opening tool to separate the speaker grate from the rest of the device.
  11. HMDX Jam Plus Speaker Replacement: passo 11, immagine 1 di 2 HMDX Jam Plus Speaker Replacement: passo 11, immagine 2 di 2
    • Carefully remove the speaker through the top of the device.
    • Apply new adhesive to the edge of the replacement speaker and the edge of the speaker grate to ensure they do not wiggle loose.
Conclusione
Montana Tech, Team 10-3, Shirk Fall 2015 Membro di Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,397
