Salta al contenuto principale
HMDX Jam Plus Battery Replacement
Cosa ti serve
  1. HMDX Jam Plus Battery Replacement, Battery: passo 1, immagine 1 di 3 HMDX Jam Plus Battery Replacement, Battery: passo 1, immagine 2 di 3 HMDX Jam Plus Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Battery Replacement: passo 2, immagine 1 di 2 HMDX Jam Plus Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Battery Replacement: passo 3, immagine 1 di 2 HMDX Jam Plus Battery Replacement: passo 3, immagine 2 di 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Battery Replacement: passo 4, immagine 1 di 3 HMDX Jam Plus Battery Replacement: passo 4, immagine 2 di 3 HMDX Jam Plus Battery Replacement: passo 4, immagine 3 di 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Battery Replacement: passo 5, immagine 1 di 3 HMDX Jam Plus Battery Replacement: passo 5, immagine 2 di 3 HMDX Jam Plus Battery Replacement: passo 5, immagine 3 di 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Battery Replacement: passo 6, immagine 1 di 2 HMDX Jam Plus Battery Replacement: passo 6, immagine 2 di 2
    • Use new adhesive to secure battery back to the rest of the device.
Conclusione
Altre 4 persone hanno completato questa guida.
Montana Tech, Team 10-3, Shirk Fall 2015 Membro di Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Membri
4 Guide realizzate
6 Commenti
Where may battery be purchased?
Thanks,
zappenfusen
warnsdorff - Replica
Where to purchase battery for hmdx jam speaker
Frank David -
Where can a battery be purchased?
robertwacker - Replica
What kind (especifications) that battery?
vecchio.farias - Replica
Where to buy battery for HMDX JAM.Bluetooth speaker
Frank David - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 37
Tutti i Tempi: 7,173
