Salta al contenuto principale
HMDX Jam Battery Replacement
Cosa ti serve
    1. HMDX Jam Battery Replacement, Opening speaker: passo 1, immagine 1 di 1
      • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
      Chiedi a FixBot
      Aggiungi Commento
    2. HMDX Jam Battery Replacement, remove rubber cover: passo 2, immagine 1 di 1
      • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
      Chiedi a FixBot
      Aggiungi Commento
    3. HMDX Jam Battery Replacement, Remove screws: passo 3, immagine 1 di 1
      • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
      • It would be wise to use a magnetic mat for the screws for safekeeping.
      Chiedi a FixBot
      Aggiungi Commento
    4. HMDX Jam Battery Replacement, Exposing Battery: passo 4, immagine 1 di 1
      • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
      Chiedi a FixBot
      Aggiungi Commento
    5. HMDX Jam Battery Replacement, Removing Battery: passo 5, immagine 1 di 1
      • Very gently remove the battery from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    6. HMDX Jam Battery Replacement, Remove battery attachments: passo 6, immagine 1 di 2 HMDX Jam Battery Replacement, Remove battery attachments: passo 6, immagine 2 di 2
      • Use a solder gun to remove the battery attachments from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 42 persone hanno completato questa guida.
USF Tampa, Team 1-1, Blackwell Winter 2015 Membro di USF Tampa, Team 1-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G1
4 Membri
4 guide realizzate
18Commenti sulla guida
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - Rispondi Condividi
Did you ever find out where to purchase a new battery for it?
DJ Ethics - Rispondi Condividi
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel - Rispondi Condividi
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - Rispondi Condividi
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 27
Ultimi 30 giorni: 109
Tutti i Tempi: 98,749
